Tell me more ×
Which one is able to perform its task efficiently and can hit a RH range of 35% to 50% in a 50L box?
Mini-Dehumidifier Portable
Mini-Dehumidifier (AC-Powered)
Dehumidifier Rod
Why a fifty-liter box? Maybe rephrase the question in terms of your actual application and problem. – Vebjorn Ljosa May 10 '12 at 11:22
@VebjornLjosa Thanks for the question. The reason is that I tried putting a Mini-Dehumidifier Portable into a 5 liter box and what I get from a hygrometer is a RH value of 10% to 15%. I was quite shocked and was wondering if the capacity will affect the RH value when the Dehumidifier is insert into a box (it can also be a cupboard or closet or something enclosed) but I would like to know if big enclosed area will result in different RH value by the same Dehumidifier & the different type of Dehumidifier as posted above. – Jack May 11 '12 at 2:04
@VebjornLjosa I would appreciate if you can help me to rephrase my question (if necessary). Thanks. – Jack May 11 '12 at 2:06
closed as not a real question by Steven, Niall C., Tester101, ChrisF May 10 '12 at 20:45
It's difficult to tell what is being asked here. This question is ambiguous, vague, incomplete, overly broad, or rhetorical and cannot be reasonably answered in its current form. For help clarifying this question so that it can be reopened, see the FAQ.
