I've just purchased a house with an old Genie garage door opener that uses the simple dip-switch remote configuration system (no rolling code, in other words). The garage has two doors, each with its own opener. Given that the size of each opener is roughly the size of a box of cheap cigars, the range is terrible (need to be within ~10 feet), and the remote generally feels like you're going to break it when you push the button, I'd like to replace the two remotes with a single smaller remote. There are a bunch of different options on sites like Amazon, Lowe's, Home Depot, etc., but most of these seem to be geared toward openers with rolling code systems. Will these remotes work with the sort of opener I have? FWIW, the current remote I have is a Genie GT90-1.
