Are steam cleaners better then the vacuum cleaners for cleaning carpets and kitchen?
Does steam cleaners can also do vacuum cleaning?
closed as off topic by Tester101, The Evil Greebo, Niall C., BMitch, ChrisF May 17 '12 at 21:02
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined by the community. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about reopening questions here.If this question can be reworded to fit the rules in the help center, please edit the question.
Check out this page but I don't know about the quality of a combo vac/steamer – UNECS May 7 '12 at 11:32
you are trying to get a comparison on apples and oranges as both work on entirely different principles:
steam cleaners use steam to sterilize and loosen dirt for mopping up with a rag which may or may not be attached to the steam cleaner
vacuum cleaners just suck up loose dirt
vacuum cleaners are better for carpets while steam cleaners are better for smooth floors
Let's be clear: "fake" steam cleaners (like common supermarket rentals) spray soap then vacuum it up. – Bryce Jan 1 '14 at 8:38
