It was mentioned in an answer to my previous question that silica gel can be heated in the oven to restore its water absorbent properties. I only have access to an induction cooker, so it possible to use that instead?
Tell me more
closed as off topic by Tester101♦, ChrisF♦ May 4 '12 at 11:36
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
