I have a few small hand-carts. One of them is the two wheel hand-truck/dolly, and one is a larger one on four wheels with an upright handle.
Both have leaky tires. Some of the tires have a slow leak that I need to pump up every time I need to use the cart, but one tire won't even hold air for 20 minutes.
Is it possible to find the leaks and repair them? Or is it better to replace the wheels?
