Are plastic ridge vents better than aluminum ones, and if so, why?
Tell me more
closed as not constructive by Tester101♦, woodchips, Doresoom, Steven, ChrisF♦ May 3 '12 at 8:03
As it currently stands, this question is not a good fit for our Q&A format. We expect answers to be supported by facts, references, or specific expertise, but this question will likely solicit debate, arguments, polling, or extended discussion. If you feel that this question can be improved and possibly reopened, see the FAQ for guidance.
PVC should serve you better than aluminum. It doesn't get cold enough for you to have those kinds of issues and will not corrode like aluminum will in the moist climate. |
