I am living in an old building where the old galvanized steel pipes are still in use indoors.
Rather than upgrading to copper pipes, can I reuse these galvanized steel pipes for hot water (from a gas heater for showering)?
I have the impression that galvanized steel pipes are very vulnerable to corrosion when used with hot water. But I don't want to change to copper pipes because some of the galvanized steel pipes are conveniently available next to my gas heater hot water outlet.
