I am doing a small installation of lock and fold flooring and find that the pieces don't want to sit flat, they curve up from the floor somewhat. I am tempted to push harder on them, but don't want to break the tongue off. Should I be using a rubber mallet to set the pieces together or is that too heavy handed for this stuff, it isn't very thick and it was expensive so I really want to be careful.
Does anyone have any tips for installing this type of flooring? It is turning out to be a little more hassle than they advertised on the display in the store.
up vote 5 down vote accepted
I can think of a few possible problems:
  1. The floor wasn't flat to start with. You typically put down an underlayment of some sort, which will deal with some floor imperfections, but it's not 100% perfect.
  2. Something managed to get under the flooring when you weren't looking. (those little plastic things yout put against the wall being a prime culprit, but those are pretty obvious when it's happened).
  3. There's something in the grove of flooring. As part of the manufacturing, a little wood chip might get in the track, which prevents it from seating correctly and locking down.
Odds are, it's #3 -- it doesn't take much. Inspect the board that you're trying to place, to see if there's any imperfections in the board along the grove, then take a look at the place you're trying to lay it into. One the last floor I helped installed, we got in the habit of looking at all edges of the board before laying them, and pulling off any bits that were flaking that might cause problems later. We also found that putting the board in the groove, then running it back and forth a few times would make them more likely to sit down on the first try (I'm not sure if it knocked out debris, or ground it down so it was small enough to not be a problem).
FYI: I finished the job and think it was mostly #3. Based on your advice I ran a small sample piece of the flooring up and down the groove on both sides of each board before laying it to clear any sawdust/burrs before placing it. I still had some 'pop-ups', but the job went much more smoothly. Thanks. – JohnFx Aug 23 '10 at 14:57
#3 has always been my problem. I've found that a small paint brush is useful to have with your "At Hand" tools. Also, watch the end groove -- they get dented and mashed pretty easily. – Chris Cudmore Nov 21 '11 at 14:41
A tapping block and a mallet are helpful to get click-lock floors seated. I used the linked block and pull bar set for a laminate floor install last week and it worked great.
Several times I encountered planks that didn't want to sit flat, even after smacking them with the palm of my hand. A few gentle taps with the tapping block parallel to the long edge of the planks seated them right in.
I found it was helpful to tilt the block upward on the side away from the plank, so that the force of the tap was driving it mostly horizontal but a tiny bit downward so the block didn't come unseated. The first few times I didn't take this precaution, and I ended up with portions of the laminate surface chipping off when the block slipped over the edge.
I've used a simple block of wood and a hammer with good success. One problem is getting the tongue seated all the way in the grove, after working it in I'd sometimes push it down with gentle pressure and use the wood block and hammer to knock it tight into the grove. – BMitch Jan 7 '15 at 19:04
