Tell me more ×
I'm trying to install a new Nest-brand thermometer in my parents' house (unscrewing a thermometer from the wall and screwing on the new one.
The first instruction in the manual is to shut off power to the house. What is the risk of not shutting off the power?
Typically a furnace will have a service switch mounted on the side of the furnace or nearby wall. It should also have a dedicated breaker, possibly two. There's no need to shutoff the entire house, just the HVAC system itself. – BMitch 15 hours ago
Sounds like CYA Lawyerspeak for a high dollar consumer device that they know will be installed by people with absolutely no experience working on electrical and HVAC systems. It's easier and causes the least liability to tell the consumer to throw the master switch for all power than try to tell them how to find the circuit breaker for the HVAC system, and possibly any ancilliary breaker to power secondary devices. All that's needed is to shut down the HVAC and make sure that it is the same circuit the 24v control voltage comes from. Once again, consumers got no VOMs, assume the worst. – Fiasco Labs 14 hours ago
Some systems are line-voltage in which case you could get a 120V or even 240V shock from the thermostat wiring. I believe the Nest is designed for 24V systems. It does seem a bit extreme to suggest turning off the power to your entire house. I would probably settle with turning off the power to your furnace and then verifying with a non-contact voltage tester to ensure none of the wires are live.
On many thermostats, you can verify they are not getting power from the furnace by removing the batteries - if this display stays on, it's getting external power. If the display dies, then its not.
Always assume it's live until proven otherwise!
I've not installed a Nest thermostat, but I have installed a BAYweb thermostat (similar concept). The precaution is with the HVAC systems that are being controlled with the thermostat, not the entire house.
In this case, safely turning off anything being controlled by the thermostat should suffice. And to be on the safe side, flip their breakers as well.
Shutting off the house seems extreme, but you could easily damage the furnace control board if you let the wrong wires touch during the installation. Most furnaces have a fuse to protect the 24V components, though.
I am an Australian based Home Automation installer and Systems Integrator rather then shutting off the entire homes power locate the circuit breakers for the Air Conditioner and switch them off.
As the power that goes to the Thermostat comes directly from the air-cons main unit (usually outside)
