Is there any method, table, equation, mathematical procedure, computer algorithm, or data base to convert lamp data such as a Philips PAR30L flood lamp or LED Par38L flood lamp to minimum housing size? Simplified, what do PAR30L or PAR38L mean? I believe the 'L' is for long neck. Also is there any table to calculate the housing, for Halo 6 inch new construction fixture, heat rise knowing the lamps dissipation in watts for a kitchen housing installed in the ceiling between the kitchen and attic. Typically on hot days the attic will see temperatures of about 120 degrees F.
Tell me more
Here's a quick breakdown of the most common residential lamps here in the US.
I cannot answer the question about the thermocouple that protects the fixture from over heating. I don't know what my attic temperature is, mostly because in the summer time the ambient outside temperature floats between 110 and 120 most of the day and about 2 months of night time temperatures in the high 90's at midnight. It's the same can as what you buy. |
Doesn't answer all of your question but try checking out Harrington lights page on identifying lights or the PDF with pictures and descriptions of light shapes and wattages. |
