I bought a replacement condenser fan motor for my outdoor A/C unit. The old unit was CW direction only. This one is CW/CCW and has 4 wires stick out of the side that change direction depending on how they are connected.
I'm concerned with leaving them out in the open subject to getting rained on. There are rubber boots that cover the wire, but I'm not sure that's gonna be enough. I've used zip ties on the wires and wrapped the seam between the two rubber boots that protect the connections with electrical tape, but I'm wondering if anyone has any tips for further protecting them from the rain.
I was thinking about taping it to the side of the motor, but I'm concerned the motor will get too hot. Should I just wrap the wires and boot with more electrical tape and let it hang? Should I not worry about it?
