Tell me more ×
I have some halogen can lights that just have a metal shell around them. The instructions say something like they need 3 inches of clearance. What is the best way to install these lights?
1 Answer
up vote 7 down vote accepted
The 3" clearance clause is referring to clearance to insulation. However, no inspector will OK these if they are near insulation, even if you were to push it 3" away. If you are installing in an insulated space you must use IC (insulation-contact) rated cans.
I've done this a couple times now (installed about 35 pots in my house) and it still takes me about 1hr per light. If it's your first time, expect it to take longer. A helper is very handy for fishing wire.
If you are unfamiliar with electrical wiring then it is best to leave this to the pros.
Assuming you are placing these in an uninsulated space, the procedure is not all that difficult if you have experience with wiring and basic electrical work. If you have never run wire before then this might be a bit of a challenge.
The particular cans you have are known as remodel cans since they can installed into a finished ceiling.
First, you need to lay out your design; it helps to do this on paper first. I've always followed the 24" away from the wall rule and 3-5 feet apart for each light rule, though it depends on how bright you want it. Rooms like kitchens usually require more light then a den. You should also consider the bulb type (wattage) and the radius of light they throw relative to the ceiling height (typically higher lights need to be spaced closer together).
Mark your layout in pencil on your ceiling. Next, use a stud finder to ensure there are no joists within a couple inches of your cans. If there are you will have to shift your layout by a couple of inches. With either a drywall saw or hole cutter, cut holes in the location for each light - hopefuly the light manufacturer provided you with a template for this.
Now you need to figure out where you are going to get power from. If there is already a fixture in the ceiling, it is probably easiest to get power from this fixture. If not you will need to pull a wire up a wall - this usually involves cutting a small section of the wall at the ceiling and notching the stud so that you can run the wire in the space created. If you are lucky there is already a switch you can take power from, otherwise you might need a brand new circuit. If you pull from an existing circuit you must ensure there is adequate capacity for your load; there are lots of answers on this site as it relates to load calculations.
Once you get your line (power source) to the first can, you then just run a cable (14/2 NMD90 usually) from each light to the next, leaving enough slack for you to work with the wire. If they are all along the same joists then it is usually just a matter of fishing the wire down the span. If you need to cross joists then you will need to drill a hole through the joists and fish wire in between them.
Connect the lights in parallel to each other and make sure to test them before you push them up in the ceiling and secure them with the clips.
This is just a quick overview of the process - each step can be fairly involved. The key to a successful installation is planning. Make sure you know where you are going to get power from, where the obstacles are and how you plan to get the electrical cable to all of the cans. Leave yourself enough time to complete the job, or plan it in stages.
One other tip I will offer is that higher quality cans are easier to work with than lower quality cans - the cheap ones from Home Depot are a pain to work with IMO and don't stand up very well.
Thanks @RSMoser for catching that "shift" error :) – Steven Apr 17 '12 at 20:49
Here's the thing, I already installed these lights. I'm wondering if I have to remove them and replace with insulated cans, or is there something else I can do? – Homer May 7 '12 at 16:20
Well, do you have insulation or not? If not then no you don't have to do anything. If you do, well, thats your call. Worst case you start a fire, slightly less worst case is that they constantly turn off due to a thermal cutoff switch – Steven May 7 '12 at 16:22
The lights I have installed are not insulated. There is blown in insulation in the attic, but I have pulled the insulation away from the lights until I had a permanent solution. – Homer May 7 '12 at 17:52
Yea, thats bad. Not to say there are not a lot of people who do just this, but its against code and could be a problem when you sell your house. Unfortunatly there are only very few re-model IC rated cans on the market, and they are expensive. If you can get into your attic then it is relatively easy to install the correct cans, otherwise usually you have to cut big strips from your ceiling and install them from below. – Steven May 7 '12 at 18:12
