I have lath and plaster in my bathroom. The west wall in the bathroom keeps crumbling into a powdery substance. My dad has fixed it a number of times but it keeps reappearing. The powdery area is all around the window and up on the ceiling. I don't see any water or feel any moisture on the wall.
How do I stop this pattern?
was it ever painted or is it bare plaster/spackle from previous repairs? – DA01 Apr 18 '12 at 3:20
I recommend replacing all or part of the wall with drywall. Specifically, greenboard. If you patch only part of the wall you may need to use furring strips or use a thicker greenboard to make it flush.
As a bonus, if you rip apart part of the wall you may find there is something else hidden back there that is causing this issue which you can address at that time.
Greenboard is OK, but I'd suggest going with one of the newer paperless boards (such as DensArmor--which uses a fiberglass surface)) – DA01 Apr 18 '12 at 3:21
