Tell me more ×
I've just bought a house that has older wooden-framed windows. The windows themselves appear to be fine, but the screens for these windows are simple aluminum frames that use the small spring-loaded pegs that fit into holes in the window frame to hold them in. As a result, the screen doesn't have anything close to a flush fit around the edges, so insects are able to crawl in.
I've noticed in some newer houses with vinyl windows that some of the screens sit in a track of sorts so that they can be raised and lowered, and as a result there's no place for insects to get around the edges. Is there any way to get a better-fitting screen for my existing wooden windows? Perhaps a screen uni
How big is the gap? Would you be able to install some sort of weather stripping between the window frame and the screen? – RSMoser Apr 17 '12 at 17:17
That's a possibility. I've considered a couple of different options, not excluding the possibility of just duct taping the sucker to the window frame ;) I was more interested in seeing if these in-track screens were something that could be added after the fact. – Adam Robinson Apr 17 '12 at 17:25
1 Answer
up vote 2 down vote accepted
What you are looking for is called a Combination Storm/Screen Window, and most hardware stores can order exactly what you want or you can pick through the selection at The Home Depot: Window Screens is a wide variety of combination storm window/screens to pick from.
Interesting...I'll have to take a look at this when I'm at the store this weekend. Thanks! – Adam Robinson May 7 '12 at 13:17
