I want to attach Hardie plank fiber-cement lap siding to my concrete garage walls. It's a very small surface which requires something like 3 boards altogether. I am only covering it for decorative purposes to hide old ugly concrete and stucco.
The garage door is trimmed with 2x6 boards and so I am attaching 3/4" (actual thickness) furring strips to hang siding. Hardie plank is 5/16" thick, so I will have 1-1/16". Is there any usable nails that I can use in finish nailer for that? I can't find anything shorter than 1-1/4". Will regular finish nails work?
Am I stuck with hand nailing those boards?
Also, they recommend 1-1/4" nails. So how bad is it if I use 1" nails?
What type of hardi plank is it ? HZ5, HZ10? – Brian Apr 9 '12 at 19:47
up vote 2 down vote accepted
I'm a little lost. First, what are you using to attach the furring strips to the concrete? I'm hoping some construction adhesive and a few concrete screws/anchors to bear the weight You could use the same thing to attach the Hardee-board directly to the concrete (with a layer of moisture barrier separating them to keep moisture from the concrete seeping into the siding). I'm also not sure why you're telling us what the garage door is framed with if these 2x6s aren't a substantial part of the anchor for the furring strips.
Anyway, assuming it cannot be done any other way, I'd say that using 1" nails where 1-1/4" is recommended is acceptable; maybe use a few more along each furring strip to compensate for the decreased "bite" of the shorter length of each nail. Understand that a pneumatic nailer will drive the nails down beneath the surface of the Hardee-board, so even with 1/16" clearance that 1" nail may contact the concrete. The only additional recommendation I would give is to nail in at a slight downward angle where possible, as if you were hanging a picture. The angle will not only give you a little extra depth to drive the nail, but the angle will increase the leverage the nail has to hold the siding, like using a nail to hang a picture.
Thanks for you advise with nails. Furring strips are attached using tapcon screws. I mentioned trim size to indicate that I don't have much room for thicker furring strips. – Uncle Meat Apr 9 '12 at 18:23
Can you recommend moisture barrier? Tyvek? Grace? Would it be sufficient to just paint those furring strips to protect them from moisture? – Uncle Meat Apr 13 '12 at 19:06
You didn't specify the siding type (HZ5 or HZ10, etc), but according to their instructions, it needs to be a 6d nail (2" long) aka 6 penny nail for wood framing. Since you are probably using 1 1/4" furring strips, you may be able to get away with 1" nail. I believe they specify 2" (6d) nail because normally it is installed outdoors so you don't want it to be ripped away in a storm or hurricane.
Lowes sells 1 3/4 siding/fencing nails made by Hitachi. I glue and hard nail 2x4s using these; it's a little costly but I've never had a problem.
