The outer walls in a log cabin are solid logs. I had a slight leakage problem through fittings between some of them which left brown stains on the logs. The leakage problem is long gone but the stains remain. Any idea how I can remove them? If I paint over them would the stains eventually seep through?
coloring on logs
Is there a tag for the special problems that those of us with log homes have? – Ross Patterson May 21 at 18:51
Had a similar problem with building a 10" round log home, some of the logs got wet. We tried everything including sandblasting to remove it.
The only solution we found was 40 grit sandpaper on a random orbital sander to really rough it up and remove 1/16" to 1/32" of wood before we switched to 120 and 200 grit to smooth it back out. Matching the stain might be tough though.
You could try Thompsons wood stripper/stain remover.You may have to do the whole wall or put a dark stain on all it to get it to all match.
Take a clean paintbrush, some water and get the wall wet again. The sooner you do that, the easier it will be to get rid of these stains.
Please explain how this will help to remove the stains. Thanks! – Niall C. Dec 20 '15 at 16:58
