Take the 2-minute tour ×
I just accidentally flushed my toothbrush down the toilet. (Bathroom multitasking: bad idea.)
The toilet still flushes, but it's draining more slowly.
What should I do?
EDIT
Phew! After 15 harrowing minutes I got it out with a coat hanger.
I've learned my lesson. Multitasking? Just say no.
Rubber gloves and a little fishing around? It's possible it's lodged just around the curve at the bottom of the toilet. –  Niall C. Apr 5 '12 at 18:11
Thanks. I couldn't get at it with my (gloved) hands. Now I'm fishing around with an unravelled coat hanger... –  dB' Apr 5 '12 at 18:15
As the comments suggested, first try and grab it with your hands. If it's passed the point you can reach, you will likely need to use a Toilet Auger to dislodge it.
Toilet Auguer
Tooth brushes tend to be problematic because of their shape relative to the trap in the toilet - they can really get wedged in there! Worst case scenario it might not be removable.
Fortunately this wasn't necessary in my case, but thanks for the answer anyway. I'll upvote it as soon as I get enough reputation. –  dB' Apr 5 '12 at 18:26
A last resort before giving up on the toilet is to shutoff the supply, disassemble it to remove the base, take the base outside and hit it with a garden hose on full blast from the bottom, reversing the flow of water and hopefully dislodging the obstruction. –  BMitch Apr 6 '12 at 2:27
@BMitch thats a really good idea, I never thought of that! –  Steve Apr 6 '12 at 17:14
