I acquired some used pressure treated 1x10 fence boards from a privacy fence teardown. Some of the boards do show some wood beetle signs where they were in contact with the ground. However, they are in much better shape than the boards on my ~20 yr. old fence so I'd like to save them as replacement boards to patch my fence.
Is there a way to stack and store these boards (for years, probably) without further rot?
I've currently got them leaning against a fence individually, to dry out. I have a shed, but I don't know if that would be good or bad for long term storage -- would it allow insect damage because of lack of airflow? I thought about covering with plastic, but again unsure because of the state of the boards.
Most of the references I can find (e.g. http://www.fpl.fs.fed.us/documnts/usda/ah188/chapter10.pdf) only talk about new lumber, not lumber that has been exposed to conditions.
up vote 0 down vote accepted
The answer is that it depends on the exact method of pressure treatment (did the chemical penetrate to the center of the wood or not) and the current state of deterioration. The main thing to protect the wood from is water; you want to keep it as dry as possible, by both preventing large amounts of water washing over it, and also small amounts of water remaining in contact long-term. Water washes away the bug-repelling copper compounds used to treat the wood. So, stacking the wood in a sheltered area (like your shed) with some spacing between boards (you can stack them in a loose grid if you have the floor space, or cut the worst pieces up into roughly square pieces you can use as spacers) should allow the wood the best chance.
Now, this is if the wood is in good enough shape to save. You may think so, but if the wood has already been penetrated by WDIs, the protection offered by the PT chemicals is likely past its expiration date. This is normal for fences; they're out in the elements, and unfortunately the copper compounds used are water soluble, which is how they get them into the wood in the first place (kiln-dry it, then immerse it in a bath of copper arsenide and ramp up the pressure to force the chemical-laden water into the grain). If the wood was well-treated, with green all the way to the core, the parts that haven't already been savaged by WDIs should stay good, but if you cut a board in half and see white wood in the center, termites and carpenter ants can eat that board from the inside out. If you see grey-brown all the way in, rot has taken hold and the board is garbage.
One last thing; whatever you do, DO NOT BURN PRESSURE-TREATED LUMBER. Not in your fireplace, not in your wood stove, not in an outdoor fire pit, not in a bonfire, not anywhere. Burning PT lumber, no matter how weathered and degraded, will release toxic, polluting smoke; the primary chemical used in PT lumber is copper arsenide, which oxidizes when burned to produce arsenic. In addition to the normal harmful effects of wood smoke inhalation, the amount of arsenic in 12 ft of 2x6" PT can kill 250 adult humans. A single 6' 1-by fence slat would still have enough to kill you and your family about 10 times over. If you don't breathe it in, it'll dissolve in the moisture in the air and be carried up to the clouds where it will fall as acid rain.
I sacrificed a few over the weekend and apart from the ends that had been in contact with the dirt they seem in good shape. Surprisingly so, given their age. – robm Apr 9 '12 at 19:29
The shed has its own issues, so I'll probably try the loose grid stacking idea under an awning. – robm Apr 9 '12 at 19:54
