Tell me more ×
What are some options for converting a trussed roof into living space?
My understanding (please correct me if I am wrong) is that the following needs to be taken into consideration:
  • proper floor joists need to be installed/sistered.
  • Knee wall supports need to sufficiently replace the webbings of the truss to support the roof
  • space needs to be considered to accommodate proper insulation between the living space and the roof where it contacts
I've seen a lot of systems/contractors that seem to specialize in this in the UK, but I can't seem to find much information for North America. Not sure why that is.
Has anyone done this? Is it at all a DIY proposition (providing proper engineering documents are approved)?
UPDATE:
My purely hypothetical method at this point (how far off base am I?):
  • install 12" floor joists 16" OC
  • install kneewall between current 2x4 truss 'rafters' and new floor joists.
  • install top cross-bracing/collar tie (not sure how much/spacing)
  • cut joist webbing (!?)
  • between knee wall peak, install 12" 'rafters'...these wouldn't be load bearing but act as spacers for insulation and interior ceiling.
  • leave gap between original 2x4 rafters and sheathing for ventilation
  • insulate remainder 10" of rafters and knee wall
It seems that the above plan would basically be converting the current truss system into a box storage truss, albeit with larger floor joists.
Am I in the ballpark? Again, I'd definitely be consulting with an engineer to do it right. Just trying to get an idea of what it would take.
With the above, I think I'd need to pull off the first layer of sheathing on one side of the roof to bring in the joists. If I had a load-bearing wall mid-span, could one bring up half-joists into the attic directly (since these joists are purely for floor support while the original 2x4's are acting as the ties?)
UPDATE 2:
Some more details of this particular example:
The attic space is 22' on the side parallel to the trusses (28' on the other side). It's a 12/12 roof, so that's a good 11' at the ridge, which even with new floor joists and a 5' knee wall should be plenty of room for a nice space.
The trusses are double cantilever style:
I also came across this in Fine Homebuilding on using welded steel as part of the rafter structure. More applicable for creating cathedral ceilings but thought it was interesting:
http://www.finehomebuilding.com/how-to/articles/framing-cathedral-ceilings-with-steel-sandwich.aspx?ac=ts&ra=fp
I'm not sure how to make a "real" answer out of this question, but yes I've done it and yes you have the major components down. Another consideration is an egress point depending on the purpose of the living space. – Steve Jackson Mar 26 '12 at 15:55
Ah, yes, egress point. Good point. And yea, if it's not really 'answerable' I understand if it gets closed. I guess I was hoping for perhaps some links to guides or case studies on how it's done. I worry/wonder if North American trusses are different than those in the UK (The UK tends to build things better it seems...) – DA01 Mar 26 '12 at 16:21
how tall of a kneewall are you looking to install? How high is the peak of the roof now? need a lot more info to really give an answer – shirlock homes Mar 26 '12 at 22:26
Good questions. It's not my house (yet) but will try and take measurements tomorrow. My guess at this point is that it's roughly a 12/12 pitch with a center height (from current 2x4 joists) of perhaps 10'. Knee wall height would be whatever would make the most sense...my guess being perhaps 3 or 4'. – DA01 Mar 26 '12 at 23:36
As a contractor, I have been asked to do something similar to this in the past. I refused the job. Roofing trusses like the one you picture below, have had a LOT of hours of engineering research put into them. They are extremely reliant on their design and construction, and mucking around with them increases the probability of a catastrophic failure. Why do you wish to extend the living space in this way, is there another direction you could go (basement, garage, etc...)? – ShoeMaker Apr 29 '12 at 22:56
show 3 more comments
It is definitely possible. My uncle has had this done in his loft. They had to reinforce the trusses with large pieces of wood, but they were single rather than double cantilever so it was easier.
Perhaps it's worth getting some quotes from professionals or hiring an advisor, as they'll be able to give you an idea of what would be involved and the complexity of the task even if you don't use their services.
It defiantly can be converted but you should be asking your self if it worth the investment. Maybe an extension / conservatory could cost in the same region but you will have much more real space.
It seems that these truss roofs could be quite difficulult to walk around in with all the cross members. I think you could remove the cross members if you go to a roof designer. Remove all the tiles and re design and streghten it to maximise space.
But it sounds like allot work for a small amount of extra space.
