Tell me more ×
I am making hurricane panels for my house using the technique described here.
The plywood I purchased is pressure treated. The sliding bolts are zinc, so I assume the screws that came with them are also zinc. Is this ok, or should I be using different screws and/or bolts?
1 Answer
up vote 12 down vote accepted
They are not actually zinc, but zinc-coated steel, also known as galvanized steel.
The treated-wood industry recommends the use of hot-dip galvanized or stainless steel fasteners for use with treated wood. Electroplated/electro-galvanized and mechanically-galvanized coatings should not be considered to be hot-dip galvanized. (Class 55, or higher, mechanical galvanizing provides galvanizing equivalent to the hot-dip galvanizing used on connectors and fasteners.)
Source: Strong-Tie's pressure-treated wood FAQ, which has additional information about various kinds of pressure-treated wood, galvanized steel, and stainless steel.
+1 definitely hot-dipped galvanized steel. If you don't, the screws will rust and rot. Just did this when I built my extra room. – 0A0D Aug 18 '10 at 18:59
