We have a below-grade basement and a exit door. There are concrete steps to the door, parallel to the house (so on your right is the house) and on the left is a brick wall. The steps appear to have been poured as one unit. However, over time it appears the whole assembly has shifted, both to the left, and then the top has sunk down. The effect of this is that water pools in some of the steps (away from the house). As part of a landscaping project, we were able to put in a little drain on the top most step, but it is not optimal (and also doesn't do anything for the other steps).
Here's a picture of the area:
Seeing as how a similar condition persists on almost every step, what are the options for fixing this? This area does not get a lot of sun either, so it doesn't dry naturally very well.
