Sign up ×
I am putting up some crown molding on top of some existing cabinets, but I only have about 12 inches of clearance. In the past when I have done projects like this, I have used a finishing nailer or brad nailer, however with this space, the tool won't fit.
What options or tool can I use to attach crown molding in this limited space?
4 Answers 4
up vote 4 down vote accepted
You can also use a nail spinner on the end of a drill. It's a small tool that chucks into the drill. Put a nail into the end of it and it spins it into wood. A final tap with a nail set puts the nail below the surface. It's a cabinetmakers tool and it prevents splitting the wood when driving finish nails into moldings (particularly oak).
I wouldn't recommend using the palm nailer.... They're not easily controlled and you risk damaging the molding itself.
In this case, to get the crown molding on top of the cabinet, I used a 90 degree drill (only needed 4 inches of clearance) and screws to get it in. I did this before I knew about the nail spinner and will add that to my list of things to try next time. – Tim Koscielski Mar 19 '12 at 6:15
You could use a good construction adhesive to glue it in the areas you cannot drive a nail through. Make sure to use a scrap piece of molding to wedge the piece against the wall until the glue dries.
I was putting crown molding on the top of a cabinet and not attaching to the wall, but thanks for the idea. – Tim Koscielski Mar 19 '12 at 6:18
A palm nailer might work.
Palm Nailer Image
I did try the palm nailer, but as someone mentioned, I ran into problems. First I bought a cheap one which had its issues. I then bought a Rigid that worked much better and I had some better control, but the wood was too hard for nailing. I kept bending nails. In the end a 90 degree drill and screws did the trick with pre drilled guide holes. – Tim Koscielski Mar 19 '12 at 6:16
I have the Rigid JobMax multi-tool with the Auto-Hammer head, which works in tight spaces. You'll have to set the nails below flush by hand though.
