I have shelves that stick straight out from the walls and want to add decorative ropes or such to make the the shelves stronger, What can I use? I would like to be able to stack many hard cover books on these high shelves.
What are the shelves made out of? A picture may help as well. – Jon Raynor Mar 19 '12 at 13:16
It sounds like you have a floating shelf. Because of the shear forces, these don't hold very much as they just end up pulling away from the wall.
If you want to pile heavy books on it, you are going to need to support it properly. The words "decorative" and "strength" don't usually go well together. I would think you need something solid and not a rope. With rope you have to worry about tensile strength, stretch and how to anchor it (will the anchor now hold the weight?).
The best thing to do is install a bracket below the shelf to support it. How many of these you need will depend on how long your shelf is and what it's made out of. You could always start with two (one on either end), and if the shelf is sagging, install another one in the center. There are "decorative" brackets out there but the basic principal is the same. Make sure you anchor these into a stud and not just the drywall or else you'll end up just pulling the drywall off your wall.
Bracket
