My sump pump recently went bad and while replacing it, I also decided to replace the plastic corrugated tubing that was connected to it.
When I turned on the new pump, the amount of noise it was making sounded like there was an elephant in the basement. Best I could tell, that noise came from the corrugated tubing getting into some resonating vibration. After wiggling things here and there, I removed the new tubing and put the old one back in and now the pump is as quiet as a mouse.
As far as I know, this is a standard corrugated tubing for use with sump pumps that I bought from the local hardware store. But it appears to be made of a slightly harder plastic than the old tubing and I think that is partially why vibration noise is so much higher.
Is there anything that can be done to eliminate the noise besides having to use really old tubing which I would like to replace at some point?
natural frequency = sqrt(k/m)wherekis the stiffness andmis mass. So if the old tubing wasn't vibrating, increasing the mass on the newer stiffer tubing should lower the natural frequency back down to where it was before. – Doresoom Apr 11 '12 at 19:02
