Take the 2-minute tour ×
My bathroom door isn't latching properly and it seems that the strike plate is not seated properly in the jamb. It's a 1950s apartment and all the door frames are metal, so I can't just chip away some wood. What else can I try?
add comment
up vote 2 down vote accepted
The strike plate sticks out from the jamb? Remove the strike plate and file/grind some material off where it is binding.
Off of the plate or the jamb? N00b question, but how do I grind metal? –  jiggy Mar 8 '12 at 19:47
Plate will be easier, and replaceable if you need to try something else. –  dbracey Mar 8 '12 at 20:28
@jiggy Use a bench grinder, or a Dremel with a grinding stone, or an angle grinder with the strike plate held in a vise. Or go with an old fashioned file. –  Doresoom Mar 9 '12 at 18:50
Bench grinder, lol. Did you miss that part where I live in an apartment :) I will try to lay about 1/8th inch of the plate on the subway tracks and it will just shear off. –  jiggy Mar 10 '12 at 2:34
add comment
Sometimes the hinges might not be where they were when it worked correctly. Make sure all your hinge screws are tight and not stripped out. this can make the door sit off kilter. Check your gaps around the door between the door and the jam. this means compare the top to the bottom and left and right. They all should be about the same distance. The first answer is correct also, but check your hinge screws. It could also be your problem.
add comment
The strike might have been replaced at some point. If you have other doors in the apartment that work properly, take that strike out and compare it to the one in your bathroom. That will tell you what modifications need to be made to get the door to close. If you have a closet or other door you don't worry about latching, just swap them out.
add comment
