After the window has been secured in the rough opening, how do you finish the inside part of the installation? For example adding a window sill and trimming out the inner portion of the rough opening, not the finishing trim around the window. Also does anyone have any videos or pictures of the process? The type and maker of the particular window i am installing is a ThermaStar by Pella 28" x 36" 10 Series Vinyl Double Pane Single Hung Window. Thank you
Tell me more
google "trim interior window" = video: http://www.thisoldhouse.com/toh/video/0,,20046338,00.html steps: http://www.thisoldhouse.com/toh/how-to/intro/0,,218130,00.html Assuming you have already: 1) insulated in the rough opening with low-expansion spray foam 2) sheetrocked to the rough opening |
