My grandmother has moved into a new house, and the aerial connection for her tv is not working. Are there any troubleshooting methods I can use to check and perhaps fix it before calling in a contractor to do it?
Right now we are getting no signal at all through the connection. Also, in our area there is no analogue tv signal, only digital. We are in Australia if that makes any difference.
Thanks!
closed as off topic by Steven, ChrisF Feb 27 '12 at 9:07
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined by the community. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about reopening questions here.If this question can be reworded to fit the rules in the help center, please edit the question.
up vote 0 down vote accepted
Is there just the one socker? If not, do the others work? And are you sure they are for the antenna? There isn't a Foxtel box lurking on the side of the house? It's unfortunately pretty common when getting a Foxtel connection to abandon the antenna based system.
You can also visually inspect the mast from the ground to see that the cable does actually go up to the antenna. If there appears to be a box on the mast, then you probably have a mast-head amp; I'd then go looking for it's power supply (it should be plugged into one of the sockets) and check it's powered on.
Past that, you're going to need a contractor. They will have devices to look at the raw signal level (you can't trust the numbers on set-top boxes or in digital TVs, I'm afraid) and know how to trace the cable in the walls and under the house, looking for splitters and such that may be faulty or bypassed.
It ended up being amp power. All fixed up now, thanks! – AkkA Mar 18 '12 at 13:02
