Tell me more ×
I have a ceiling light/fan fixture in one of my rooms connected to a single electrical switch. There are two pullchains on the fixture, one that controls the light, the other controlling the fan. I'd expect the fan chain to switch it among fast, slow, and off. However, whenever the switch is on, the fan motor is running, and the chain just switches between fast and slow.
Is there something wrong with this fixture?
Is it just wired wrong, and should have two separate switches?
with a hammer? ;) – naugtur Aug 17 '10 at 9:00
@naugtur: Nope, sorry. The question we were looking for was "What is a Sawzall?" Maybe you'll have better luck in the Daily Double. – Doresoom Nov 12 '10 at 22:33
Depends on how it is wired. The single switch will control the fan and light simultaneously. If you want the light off, then you pull the chain for the light. The nice part about having the light on a different switch is you can simply go into a room without having to turn on the fan every time and have a nice bright fixture in the room. The downside is that you have to hit the switch every time since the pull chain kind of loses its purpose and is now redundant.
Now, whether you have three speeds or not is up to the manufacturer of the fan. Most fans made recently have three speeds. We have to know the make/model to find out for sure. Doubt it is broken though.
It sounds like someone replaced the pull-chain switch for the fan with one made for a light.
Your fan switch is shot. You can get replacement switches at big box stores. It is probably not a light switch or else the fan would simply turn on/off rather than what you see - slow/fast with no off. Five bucks and a half hour and you will be fine.
