my microwave is all installed fine. Just when i start it the fan makes rattling sound. It stays till the entire time cycle is done and when it stops turning u can hear the fan slowly stopping with the noise rattle as if something is hitting between the fan blades.
Tell me more
closed as off topic by Niall C., BMitch♦, Tester101♦, ChrisF♦ Mar 21 '12 at 16:52
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined in the FAQ. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about closed questions here.
A microwave is not an appliance a homeowner should work on. There are lethal voltage and currents from the power transformer, and the magentron tube gives off RF radiation. If you don't know what you're doing, you can get badly hurt! |
