When my washing machine drains it sometimes comes up and out of the open pvc pipe in the service closet where the water heater would drain. I've found lots of posts where people speak of the washer standpipe overflowing, but can't find any info on what would cause my problem. When the washer drains I have to stand at the service closet (next to each other in the garage) and watch/listen. First I can hear gurgling, then hear the water coming up the pipe (similar to the sound of filling a glass of water), then I can see the water just before it emerges and floods my service closet and garage. If I turn the washer off and on as it drains this doesn't happen...but not really feasible for the long run. Any ideas?
It sounds like the pipe is partially blocked and water can only get through at a slower speed. The drain at the hot water is the lowest point so that's why it is coming from there. The blockage could be anything, from debris that came in through the pipe in the service closet or a sock that made it out of the washer. Since it's after where the water is coming out of the service closet then you might be able to get a drain snake the problem but you might have to get an expert to get it cleaned out.
lqlarry is likely right, and using a snake to clean out the line is the first step. (+1 Larry)
It could also be a problem with the plumbing vent. If that is the issue, you would likely hear a gurgle after you shutoff the washing machine and the water gets down to the P-trap, not unlike the sound the toilet makes at the end of the flush.
The other issue I can think of is that the plumbing drain is improperly sized or sloped. If that's the case, this problem would have always happened, and wouldn't be a new issue.
Thanks for your responses. BMitch, it does gurgle, so that's good to know. I just bought the house so I don't know it's plumbing history. The home warranty people sent a plumber out who tried to snake it from the service closet, but he said it had a drum trap in the line instead of a P trap and he couldn't (?). I had another plumbing company come out last week and they thought the drain line is too small and too short. They're coming tomorrow to dig an outdoor cleanout as I have a problem with the back bathroom, but I'm unsure what to do about this issue. This second plumber wants me to file a – Carey Feb 19 '12 at 21:25
We hooked up water hose to a stopper from Ace. It kept water from coming back and force washed the clog out. I did use liquid Plumber followed w/hot water first. The clog looked like big pieces of dried washing powder.
Could you add a link to the stopper you used? – Niall C. Jun 30 '13 at 13:25
Think air behind water. The drain must be properly vented for it to withstand the rush of water from a washing machine pump.
If the washer drains into a dry well, then the dry well is probably clogged with lint. You will have to dig it out or dig a new one. We had that problem at my son's house.
It's because the water flows out faster than the pipe can drain. The easiest way to fix this is to seal up the washing machine waste hose against the open PVC pipe. Some gaffer tape should do the trick.
Otherwise you could fit a holding tank above the drain which is allowed to fill and provides time enough for it to drain out without overflowing.
A harder option would be to increase the size of the waste pipe so that it can take a larger volume of water through it.
Matt's right. I've lived in two separate houses with this same issues. Washers today drain at higher volumes than their predecessors in years past. Will try all ideas this time. But, last time, I recall using a fire hose to drain to the ditch... not a great idea, but what to do? what to do? – user15094 Sep 14 '13 at 19:43
This is not a great idea because turning the drain pipe into a pressurized system rather than one with an air gap will create a siphon that will cause the washer to never stop draining once it starts and there is still water in the tub. This will obviously waste a huge amount of water, but it could also burn out the pump and cause a flood anyway as there's simply only so much water the pipe can accommodate. Start by snaking it and go from there. – iLikeDirt Apr 22 '14 at 13:55
iLikeDirt - Pressure equalisation comes from the air inside the washing machine. There is no siphon. I've had to do the seal method and it worked but was done temporarily. It didn't cause any problems at all and it indeed did drain. – Matt Apr 22 '14 at 21:51
That's true, as long as the machine isn't filling at the same time. Anytime it's both draining and filling, you'll get a siphon. – iLikeDirt Apr 22 '14 at 21:54
I only had that problem when I purchased a newer washer. I purchased a rubber piece from a hardware store, it came with two clamps that goes around each end. One end goes over the pipe and the other end goes over the rubber pipe to the washer. Tighten the clamps. No more problems with water backing out because of the tight seal. It didn't cost a lot and I didn't have to call a plumber which would have cost money and the problem not fixed.
What was this rubber piece called? Can you provide a link? – Niall C. Nov 4 '13 at 1:44
Get the washer drain piping snaked out. Have the plumber run down the vent stack for the washing machine. This should take care of your problem.
protected by Community Feb 19 '15 at 18:19
Thank you for your interest in this question. Because it has attracted low-quality or spam answers that had to be removed, posting an answer now requires 10 reputation on this site (the association bonus does not count).
Would you like to answer one of these unanswered questions instead?
