Take the 2-minute tour ×
Possible Duplicate:
Which material should I use for a whiteboard that would erase easily?
I would like to convert my walls (at least one of them)
into a laminated surface so I would be able to write things on it.
Because the wall is massive, and I do need a massive space to write on,
I'm not sure what kind of a solution there is in order to laminate/coat it
with a thin layer of writable material (as in, easy to erase and re-write over and over again).
To clarify, I basically want to convert my wall to this
without finding a huge board.
marked as duplicate by Steven, Doresoom, Niall C., ChrisF Feb 15 '12 at 21:11
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
you mean like a whiteboard with dry erase pens? –  ratchet freak Feb 15 '12 at 18:01
This Question might help, or This Question, maybe This Question, or even This Question. –  Tester101 Feb 15 '12 at 18:08
Ideapaint seems like the closest thing here, however it's not available in Europe (plus it's quite expensive) –  Asaf Feb 15 '12 at 18:50
add comment
whiteboard paint, quick google search should give you a few options for that: Google Search
another idea is vinyl wrapping the whole wall, but that could cost more than the whiteboard paint - The wife wraps boats in vinyl, and says it would cost about 200 quid to wrap a 7m2 wall and all you would need to do is give it a really good sand.
She also has in the office a white board they made with the vinyl and it's about 5 years old and still going strong :)
Hope that helps.
Martyn
Edited, got some more info from the wife on vinyl wrapping and it seems like a good way to go, if you could find a local company to you might be able to get it cheaper. –  SmithMart Feb 15 '12 at 19:29
add comment
Another option is to go the chalkboard route: just like there is whiteboard paint, there is chalkboard paint. You just paint it and you have a usable surface for chalk. Some examples:
My brother has his utility room wall painted in this and it's great. Good for grocery lists, to-do lists, and lots of doodles.
I live in a rented apartment and the walls are white.. can't go in that direction –  Asaf Feb 15 '12 at 22:05
add comment
