I am not asking how high to mount the shower curtain rod (that is easy to determine from an existing shower curtain). I am trying to figure out how far "into" the tub it should be mounted. I want the curtain to not be in the way when showering but still have the bottom edge inside the tub.
I see a few possibilities, what the pros and cons of the following options:
- Line it up with the inside of the tub but that seems like it will be prone to "billowing in" when showering.
- I could line it up over the outside edge of tub.
- Center it over the tub curb.
- Put it "outside" of the tub completely
