Some additional reasons a fridge may be running too much, beyond what sharptooth posted::
- Thermostat may be set very low: check recommended temperature level for the kinds of food you want to store.
- Thermostat or temperature sensor may be damaged or in need of maintenance.
Also, I know it's recommended for a fridge to have a certain amount if clearance behind, around, and underneath. If it is too close to the back wall or there is a bunch of junk under/around it preventing proper circulation, it can adversely affect it. I am not sure if this will cause it to run more, or just be less efficient.
