Tell me more ×
I am installing a new linoleum floor in a small bathroom (approx. 6' X 6'). This is a replacement for an old linoleum floor. The replacement will be a single piece.
Talking with the local big box store flooring expert, he recommended not gluing it down.
It would be tempting to not glue it down since the linoleum floor will be a single piece and will be held down on all sides. But while I would love to make things easier for myself and not use glue, I am not so sure this is a good idea.
Would it be a bad idea to not glue down the linoleum floor?
Did the "expert" say why not to glue it down? – Niall C. Feb 2 '12 at 16:14
Not really... just that it is held down on all sides. Sounds like you are skeptical, just like me. – Jeff Widmer Feb 2 '12 at 16:28
I'd be afraid of wrinkles and/or bubbles developing over time. – Tester101 Feb 2 '12 at 17:13
What are the manufacture's installation recommendations? – auujay Feb 2 '12 at 19:19
There is a whole new generation of fiberglass, not vinyl, flooring that is self laying. The various manufacturers say wit will lay flat, not curl or bubble without adhesive. I have my doubts, but admit I have not used it without adhesive. The manufacturer does says that when adhesive is used, it can only be "Releasable Pressure Sensitive Adhesive", never standard vinyl sheet goods adhesive.
In a small room like you have, I'd test the no glue theory. If it doesn't work well, it's easy enough to go back and glue it down with pressure sensitive adhesive.
Make sure you have the right vinyl flooring that does not require glue/adhesive and you do decide to use the adhesive make sure it is the releasable pressure sensitive adhesive. Good luck
