Tell me more ×
I have a 1969 Cape Cod 2,300 square feet, brick and vinyl sided home with cathedral ceilings that I want to update insulation in. I have the original R-7 fiberglass in the walls and R-12 in the ceiling. The roof has soffit and gable vents. There is only a 4 inch access in the ceiling from the attic.
Filling this with insulation would block the venting from the soffit to the gable vents. I had some companies offer to blow cellulose in the space and make it a warm roof. Other companies said not to block airflow because it would cause problems with the roof. The house is 50 feet across the back. There is a lake view so the first story has three large sliding doors and a wide chimney. There is less than 6 linear feet of wall to insulate.
All the bedrooms are upstairs and on the back wall and again have very little wall due to the chimney, French doors and large windows. I got a quote for about $2000 for retro foam in the side walls and front of the house. They said it would make a big difference stopping airflow in the walls because the side of the house took a lot of wind from the lake.
Another company would not give me an estimate because they said due to the large amount of windows and doors and because the ceiling was under insulated, retro foaming the walls would not make a noticeable difference. I have replaced all the doors and windows in the house and installed a high efficiency furnace. I live in Michigan with cold winters and warm summers.
Is it worth insulating whatever I can?
Update
The ceiling is built to the trusses. I went up into the peak and realized that there are cross braces so there is no way to insulate the ceiling over the bedrooms without removing the roof or tearing out the plaster ceiling. So the question is: will I notice a difference in comfort putting retro foam in the walls if the roof is only about R-12. I realize that it will take many years of energy savings to make up the $2000.
Can you post some pics? If this is a Cape, why the small cavity above the 2nd floor ceiling? Are the ceilings built to the trusses? have you had an independent energy audit done? Give me something to work with here. – shirlock homes Feb 1 '12 at 22:39
The simple answer is "yes". Every piece of insulation you put in is a bit of heat that's not lost to the outside world. This is better for you as your house is warmer and your fuel bills are lower, it's also better for the environment as you're not using as much energy.
The more complex answer is "it depends". Buying and installing the insulation costs money (you don't say!) so the immediate equation becomes "is this cost less than the money I'll save over X years?". It's the answer to this that will, largely, affect your decision on whether to insulate or not.
The company who wouldn't estimate may be right (for their system) in that it would cost $2,000 (say) to do the work, but you'd only be saving $20 a year on your heating. This would mean it would take 100 years to pay back the cost. Now, if you can find a system that costs less then the proposition becomes more economical. Insulating the ceiling/roof space is a good thing to do anyway.
However, if your primary concern isn't the savings then you might decide to go ahead regardless.
There are some govt programs as well as programs sponsored by utilities. Those are worth checking into. They will do an energy audit on your house and will also retrofit insulation(usually blown in kind) Those are often free for qualifying homeowners even with medium to medium high income
