I recently replaced the fuel tank, fuel line, and carburetor on a 8HP wood chipper/shredder. The first time I tried to pull start it after completing the work, it started right up.
A few weeks later I tried to pull start it again, with no luck. After using some "engine start" spray, it again started right up and ran just fine. Again a few weeks later, I tried to pull start it with no luck.
Is there something I'm overlooking or some type of adjustment I can do to fix this?
closed as off topic by shirlock homes, Vebjorn Ljosa Jan 31 '12 at 22:43
Questions on Home Improvement Stack Exchange are expected to relate to home improvement within the scope defined by the community. Consider editing the question or leaving comments for improvement if you believe the question can be reworded to fit within the scope. Read more about reopening questions here.If this question can be reworded to fit the rules in the help center, please edit the question.
this is probably the wrong forum for this question. – shirlock homes Jan 31 '12 at 21:34
@shirlockhomes - Is there another StackExchange forum for small engine repair? There are a few question of similar topic here, here, etc. – CodeNaked Jan 31 '12 at 21:43
@CodeNaked - either Gardening and Landscaping or Motor Mechanics - both still in beta. – ChrisF Jan 31 '12 at 21:57
The questions you link to were posted before (or around the time) those sites were created and we don't really like migrating old questions. – ChrisF Jan 31 '12 at 21:58
