Tell me more ×
I bought a new house about a month ago. In the apartment that I moved from, I had a cheap rubber drain cover that seemed to work very well at preventing hair from getting into the drain, similar to this guy:
Spikey rubber drain cover
But the shower in my new house has a more permissive drain cover:
Doesn't trap hair well
I'm pretty sure that more hair is going down the drain now than it was with the old solution, but hair still went down the drain with the old cover. I had a couple questions relating to this situation:
  • How worried should I be about hair going down the drain?
  • Should I replace the new drain cover, or add a secondary cover?
  • Will I just have to resign myself to unclogging the drain periodically irrespective of drain cover configuration?
Its worth mentioning: lye will turn hair into nothing. Pour a pound onto the drain and follow it with a quart of near-boiling water. – insta Mar 1 '12 at 23:06
up vote 6 down vote accepted
Hair going down the drain is inevitable and no solution will completely prevent it.
Some drains can be replaced from above while others cannot. Unless you are having a chronic problem with clogging due to hair, I think you are making more work for yourself than necessary. If you try to remove it and can't, or don't install the new one correctly you'll go from letting a bit of hair down the drain to a full-scale leak.
It's also not going to stop draining completely out of the blue; it will gradually start draining slower, so it's very unlikely that this will become an emergency one night. I'd just wait and see. If you have a problem, then you'll obviously need to unclog it, otherwise, enjoy your shower and don't worry too much!
If you think it answers your question please mark it as an accepted answer by clicking the check mark underneeth the vote count! – Steven Feb 1 '12 at 16:49
Thanks for the answer, especially for pointing out the potential for creating a problem where none existed to begin with. I'd expected that it was something that I would have to deal with in any case, but I wanted the opinion of someone with actual experience to judge the relative importance of preventing hair from going down the drain. – Shawn Furyan Feb 1 '12 at 16:50
I am afraid the hair clogging the drain issue will always be an issue, you need to look for a hair filter which fits right under your existing drain cover plate.
The understanding is, when your water drainage seems to slow down, remove your existing cover and clean out the hair trap below.
Thanks for the suggestion. A quick google search didn't seem to lead to an obvious source, so I'll have to look into this option when I have more time. – Shawn Furyan Feb 2 '12 at 19:07
