Tell me more ×
While my roof was being replaced, I requested that they install two roof vents. One for laundry and one for bathroom fan. They installed two of these. I just tried connecting the bathroom fan to this vent but, when on, the fan gets noisy and I can't feel much air coming through the roof vent. I'm concerned it's not compatible with this use.
The roof vent is about 4" in diameter at the base. Under the (non-removable) metal cap it appears to have a rubber flap that opens under pressure, covering a ~2" diameter hole.
One other thing to mention is that this is a shallow pitch roof (about 5 degree?) on a row house.
Photo of roof vent
up vote 8 down vote accepted
What you show in the picture is known as a One-way Breather Vent (there are also two-way). Its intended purpose is to provide pressure equalization throughout the roof system and also provides ventilation for the insulation system.
In some buildings that do not have a vapor barrier (even some that do), pressure changes inside the building can be forced upwards through the plywood sheeting and potentially cause the roof system to pillow upwards and damage its adhesion. The breather vent gives the pressure an avenue to escape without causing any damage to the roof.
I would not recommend venting anything through the breather vent. Most of the time breather vents are install through the roof system and do not penetrate through the substrates. By cutting through the insulation and plywood you're essentially turning into a general building/attic vent and losing some of its effectiveness.
I called up the roofer. It's called a breather vent and he still claims it's compatible with dryer and bathroom fan venting. When I search for it I see they're intended to be used to vent moisture between waterproof layers of the roof. I have no idea how he knows the name of this thing but doesn't know they're intended purpose. Up side is that he's going to replace them with vents that will work for ours needs.
