Tell me more ×
I bought my house 3 years ago which has a latex-based painted deck surface and decorative fence around the edge. After shoveling snow each winter, the deck surface is chipped with raw wood exposed. I have painted it twice but this seems like a poor approach going forward. I would like to remove the paint from the surface (3 layers) and stain/seal the deck -- eliminating the need to take care of it's surface each spring.
What do you recommend?
up vote 1 down vote accepted
For the main deck, I would recommend a floor sander, similar to what's used for finishing hardwood floors. Put a 100-120-grit belt on it and take it back and forth along the deck in the same direction as the planks until you see bare wood. Once you have bare wood, I would apply whatever stain or sealant you want very quickly thereafter, as you have just removed a large portion of both the artificial and natural weather and bug resistance the wood had.
A handheld orbital or belt sander will get most of the stuff off the vertical components (handrails and pickets). You'll need a "corner cat" or other detail sander, or some elbow grease, to get the paint out of crevices and detail work.
You will not be able to avoid taking off some wood along with the paint. Paint (especially a product designed for this kind of outdoor application) will seep into the grain of the wood, and you will be removing wood before you see the color disappear and bare wood show through.
By the way, you will still need to maintain the deck after staining and sealing. The stain will last for quite a while, but you'll need to re-apply the water seal at least once a year, once every 6 months if you get a lot of rain.
Use a pressure washer. The best solution to removing paint from a surface like this. You can buy an inexpensive one for roughly $100, or rent one for less than that.
The problem is, stain does not last forever. If you don't like gray wood, then you will need to stain/seal the deck periodically anyway, and you may well need to do so more often.
I contacted 2 folks doing pressure-wash and they said it wouldn't remove the paint. they recommended sanding. – susan Jan 27 '12 at 15:48
I also contacted a residential sandblast company and they indicated that it would damage the wood. – susan Jan 27 '12 at 15:48
It's going to take a lot of elbow grease in the form of scraping and sanding. After you do this, it might be helpful to pressure wash it before re-staining it.
The easiest solution will be to keep painting it. As the other answer points out, neither stain or paint lasts forever, and no matter what you do, you will need to keep refreshing it every couple years.
You don't mention what type of wood it is, but ceder, for example, will gray but otherwise is pretty resilient to nature and will last a long time even if you don't do anything to it.
