Tell me more ×
I think I've had it with traditional tiled showers...I can't stand the site of mold in between tiles, on the tiles! on shower curtains, on shower doors, etc.
I think I'm pretty clean, but I always will see little bits of mold.
How can I build a shower that would minimize mold growth?
What materials would help? What about concrete? Can I treat the surface with anything?
What kind of enclusure structures would work? Can I treat the shower curtain with anything? What if the door were stainless?
Do I build a dehumidifying unit into the bathroom?
I'm looking for the u Latinate bathroom/shower design.
I now that what ever the solution, cleaning will still be required...
up vote 6 down vote accepted
General construction advice for 'general' showers:
In/on the walls:
  • use RedGard as a vapor barrier over the cement board
  • use paperless or blueboard sheetrock
  • use mildew resistant pain
  • adequately vent the room with a proper exhaust fan
In the shower construction itself:
  • seal all caulk properly
  • make sure standing water can't puddle
Now, all that said, I pretty much agree. Showers as they are today aren't really designed as well as they should be IMHO.
For inexpensive solutions, I'm actually a fan of the more modern pre-moulded systems. You can get systems that look quite nice for under $1500 that come in 3 or 4 full-wall sections with gasket seems. I know folks tend to consider them 'cheaper' than a true tiled shower, but I actually find them much more intriguing from an engineering standpoint. They just make more sense to me in a modern home.
For more quirky/unique solutions, I've seen:
  • metal sheeting. Corrugated Galvanized sheets, for example. Copper as another.
  • all glass
  • sealed monolithic concrete (note that concrete is extremely porous so would have to be sealed with something like an epoxy coating)
And...most recently...we stayed at a new hotel a few weeks ago where the shower walls were made out of solid slabs of the same counter-top material as the vanity. It looked really nice actually, I'm guessing it was a Corian like product.
Wow. Really good suggestions! There's hope aft all! – milesmeow Jan 25 '12 at 5:32
Search for "solid surface" shower walls. There are several makers. – Bryce Aug 11 '12 at 5:33
After doing some research, I found that there is:
  • moisture resistant caulk
  • paint that has antimcrobial additives
Adding a ventilation fan helps...with proper usage of course, i.e. running it for 5 minutes after showering.
So potentially using those elements in the shower/bathroom would help quite a bit.
