Tell me more ×
Do electrical boxes have to be flush to the finished surface? Can they recess any depth into the wall by as much as 1/8" or 1/4"?
Edit: I appreciate everyone offering alternative solutions to making a non-flush, already-installed box flush to the finish, but remember that I am looking for an objective answer regarding whether or not the box has to be flush to the wall. This is new work, so if I can get by with having it recess into the wall by 1/8" or 1/4" then I will do so. Otherwise, I will have to alter my plans.
up vote 13 down vote accepted
They make box extenders, that can be used to extend boxes to meet the finished surface.
2008 NEC says...
ARTICLE 314
Outlet, Device, Pull, and Junction Boxes; Conduit Bodies; Fittings; and Handhole Enclosures
314.20 In Wall or Ceiling. In walls or ceilings with a surface of concrete, tile, gypsum, plaster, or other noncombustible material, boxes employing a flush-type cover or faceplate shall be installed so that the front edge of the box, plaster ring, extension ring, or listed extender will not be set back of the finished surface more than 6 mm (1⁄4 in.). In walls and ceilings constructed of wood or other combustible surface material, boxes, plaster rings, extension rings, or listed extenders shall be flush with the finished surface or project therefrom.
This might also be relevant.
406.4 Receptacle Mounting. Receptacles shall be mounted in boxes or assemblies designed for the purpose, and such boxes or assemblies shall be securely fastened in place unless otherwise permitted elsewhere in this Code.
(A) Boxes That Are Set Back. Receptacles mounted in boxes that are set back from the finished surface as permitted in 314.20 shall be installed such that the mounting yoke or strap of the receptacle is held rigidly at the finished surface.
My issue is that I need to install new work boxes so that they extend 1 1/4" beyond the stud. This way, when my second layer of 5/8" drywall goes up, it will be flush. I don't have enough depth with the boxes I am using to go out 1 1/4", so I am wondering if I can extend it 1 1/8" instead. This means the box will be recessed into the wall by 1/8" and I am wondering if that is okay. I don't want to install a box extender for just 1/8". That would be more for old work installs, I'd think. – oscilatingcretin Jan 22 '12 at 18:27
@oscilatingcretin I'll look for NEC reference later, but my understanding is that the box must extend to the finish level. – Tester101 Jan 22 '12 at 18:29
I'm not certain on code; most of the boxes I've seen tend to be somewhere between flush and 1/4" recessed, just by the nature of construction. Boxes are flexible, positioning is imprecise, and wood can have a bit of warp. The problem I've found with boxes being too far back is getting screws to reach the mounting holes in order to install outlets, switches, faceplates... Box extenders help with this as well. – Scivitri Jan 22 '12 at 19:01
Scivitri - That's what I've noticed about pre-existing boxes in my house. Still, I'd rather know for sure rather than follow the previous guys' example in the event that they did it wrong. Tester, your help is appreciated. – oscilatingcretin Jan 23 '12 at 14:15
@oscilatingcretin Found the NEC article, see edit. – Tester101 Jan 23 '12 at 17:50
show 1 more comment
Since you say new construction you can get adjustable boxes if not from a big DIY box store then you can get them from an electrical wholesaler.
Adjustable box
If you use the box extender make sure what you buy has a UL on it, or whatever country you live in stamp of approval.
Here's the spec sheet on the adjustable box. Here.
I have a few of these from Carlon, but I like this design. These are more expensive than the $0.75 nail-in boxes I picked up, so I'd rather set the nail-in box at just the right position rather than install a more expensive box just so I can adjust it later. – oscilatingcretin Jan 23 '12 at 14:18
@oscilatingcretin - People that use these use them more in kitchens and bathrooms where they are not sure of the depth of the tile or things like that. – lqlarry Jan 25 '12 at 4:41
All you have to do is use a cheap plastic nail on box, cut the plastic off that holds the nail, and fasten it with 2 drywall screws from the inside of the box.
Are you allowed to have screws exposed inside the box? – BMitch Jul 22 '12 at 13:25
That would be pure hackery, and is not allowed by code. – kreemoweet Oct 13 '12 at 3:24
