I was thinking of using a mask to cover my nose so that smell / smoke will not get into my nose while I am doing some repair work.
Beside using mask, are there better alternative such that I can still breathe normally? (The mask do make breathing quite difficult sometime. The worse case is using a oxygen tank but it seems to be a "over-kill" solution.)
Would appreciate if picture / illustration can be included.
