I have to attach some skirting boards on recently plastered walls and openings. The issue is that the floors on each side of the opening are at different levels, therefore the opening has a step on it. What usually happens with the skirting board on each side and around the opening?
Do you not put the skirting board around the side of the opening? And if so, how do you finish the edge of the board to meet the opening so that it looks good?
Obviously with the floor levels being different you cannot just wrap the skirting board around the opening as it will not line up on the other side.
Hope this makes sense.
Edit: Here is a picture. The step is not yet tiled, but it shows the level differences.
