My furnace pilot light keeps going out so I changed the thermalcoupler now the furnace will come on and heat up to the degree set on my thermostat, then the pilot goes out and the furnace will not come back on. Could the thermostat be bad and cause the pilot light to go out?
If the pilot light keeps going out, the culprit is probably one of two things, with a third being unlikely but possible:
