I have old hardwood floors in my home that I'd like to refinish myself. I'm ok with all sorts of manual labor, but I'd like to know the preferred method for refinishing them without damaging my walls or baseboards.
Belt-style floor sanders were current years ago, but more recently the best bet is a random-orbit style sander like the Varathane ezV sander. The random-orbit sanders don't have nearly the risk of grooving that the belt sanders do, and these ones also have a built-in vaccuum which collects a large portion of the dust, unlike the sanders of my childhood. I've sanded both floors of my house using that system; each floor took about a 3-day weekend start to finish using a process similar to this one. I did find that I needed to use a hand-held belt sander for the edges, and since our floors are not all that even we used it to get the existing finish out of some of the deeper spots in the floor as well. If you pull out your trim and use some care you should be able to get right to the edges without having to do more than touch up the paint on the trim. We just used the water-based polyurethane and have been quite happy with the results, but it's absolutely worth it to put down as many coats as you can - we ended up doing 4. |
There is a good step by step guide here that should help. You will want to practice a bit and make sure you are comfortable with the sander before starting, and make sure you keep the sander moving. *Make sure before you start sanding you remove ALL staples and pound in any popped up nails, they can rip the sand paper and if you don't stop fast enough after it rips you could damage the floor. |
I rented the Varathane sander as mentioned in the other post from Lowes. I also purchased the water based finish and sanding disks. There was an instruction booklet with the sander that walked you through the process. I used a handheld random orbital sander to sand in the corners. The entire process cost about $150 and took two days. I sanded down to the bare wood the first day, cleaned up and put one coat of finish on. I put 4 more coats on the next day with a light sanding before the last coat. |
Rent a drum sander, but practice in an out-of-the-way area first! You can easily sand grooves into your floor. With the drum sander you should be able to get within a few inches of the baseboards, then you'll need to use some type of hand sander. |
