Tell me more ×
Bought my Mum a Dimplex Panel Heater for Christmas.
My plan was to plug it into the single socket beside where I am mounting it however it did not come with a plug and look like it should be wired into a fused unit.
Can I just stick a 13A plug on it and use existing socket? Its only 0.5KWH.
Could you link to the product, or include a model number? Is it designed to be installed as a permanent fixture (hard wired)? – Tester101 Jan 6 '12 at 15:08
Product URL: alertelectrical.com/prod/76/… – Paul Brown Jan 6 '12 at 15:13
Found the Installation Instructions, but could only find it in French and German (neither of which I can read). – Tester101 Jan 6 '12 at 15:45
The picture on the product page appears to show a heater that is wired directly as opposed to plugged into an outlet. – shufler Jan 6 '12 at 20:46
show 2 more comments
1 Answer
up vote 5 down vote accepted
These are designed to permanently wired through a fused switch. As gregmac points out in his comment there may be insurance issues if you use a normal plug and socket, particularly in area of fire risks.
However, you can replace the current socket with a fused switch panel. Make sure you get one with a hole in the surface for the wire to go through.
Something like this
