Tell me more ×
my Maytag DW-2 dishwasher started leaking water from a small hole under, near the back and to the left whenever it starts filling with water. It must leak +-1 cup then stops leaking for the duration of the wash. Any idea why it would do that?
Update:
I have 2 more photos:
the inside lock looks like an X inside an O. Presumably the ends of the X should fit in the 4 notches to take it out but it seems that a special tool must be required to twist it in place.
this is where it leaks:
Can you provide a picture of where it is leaking from? – Tester101 Jan 6 '12 at 13:22
I do, how do I show it? – dan Jan 6 '12 at 14:59
If you edit the question, there should be a button to add an image. If you don't have the button (not sure how much rep you need to add images), you can post the image to imgur, flickr, or some other image hosting site. Then add the link to the image either as a comment, or in an edit to the question. – Tester101 Jan 6 '12 at 15:02
it won't let me do it cuz I'm new. Here's a link to the pix on flick: flickr.com/photos/11533240@N07/6647338393/in/photostream – dan Jan 6 '12 at 15:20
up vote 2 down vote accepted
Bad Seal! Or cracked pipe.
You will need to take it out completely.
Properly dismantle it in and open space and trace/examine the source while the power is on
(this can be dangerous so do not take chances)
If it only happens on the start- maybe it the inlet pipe cracked, seal perished.
If you do not feel comfortable with dissembling it call a recommended local service man.
I found the problem: the injector seal ring leaks. Now, if I can just figure out how do remove it... – dan Jan 6 '12 at 18:48
Put in a photo of where it is.. it could not be that difficult? atleast you know the problem now. Please consider upvoting or accepting answer if a post has helped you. – ppumkin Jan 6 '12 at 18:52
I put 2 photos here: flickr.com/photos/11533240@N07/6648458069/in/photostream the inside lock looks like an X inside an O. Presumably the ends of the X should fit in the 4 notches to take it out but it seems that a special tool must be required to twist it in place. the outside pix is here: flickr.com/photos/11533240@N07/6648457897/in/photostream this is where it leaks – dan Jan 6 '12 at 19:11
maybe I can just apply some sealant (silicone) around it... – dan Jan 6 '12 at 19:15
You can try- use water resistant silicone and clean the area on the outside well with alcohol(not spirits will remove paint) and then apply the silicon around the pipe and injector seal in an even way- But it would be better to replace the seal. – ppumkin Jan 6 '12 at 19:27
show 7 more comments
I had the same problem.
To remove the injector is very easy: pull the hose away from the molded U and at the same time, pull the injector away from the side then rotate clockwise a half turn to line up the hex. But the leak is not at the seal; water backs up to the vent on the injector and runs down the injector. I lowered the water flow and it stopped leaking.
