Sign up ×
I intend to relocate my washing machine and electric dryer within the basement. The dryer will then be about 2 feet from the furnace. Is that OK?
can you please re-write this with proper casing? there's no one to yell at! –  Steven Jan 5 '12 at 18:07
@Steven - or you could propose an edit, like Steve Jackson did :) –  The Evil Greebo Jan 5 '12 at 18:14
I didn't think it would let me since I wasn't adding at least 6 characteres, just changing the case. I know for next time! –  Steven Jan 5 '12 at 18:21
As far as I know, as long as the electric and gas lines don't actually touch, there's no more reason to be concerned about the gas and electric being 2 feet apart as there is 20 feet.
If you have a gas leak from the furnace, the furnaces own ignition system (pilot light or electronic sparker) has as much chance of setting off a blast as the dryer.
Check the specs on the devices. They will each have some amount of specified clearance, and you shouldn't get closer than that number (for the dryer it may be zero on the sides, but I bet the furnace will be at least a foot all around).
Beyond that, make sure there's enough room to get in between the dryer and furnace to work on the furnace (you don't want to have to start furnace work by dragging the dryer out of the way!).
Otherwise, you should be good to go.
Good point - gas appliances usually need a certain amount of air flow, and if your chimney stack isn't double function (intake/output in the same pipe), you do want space around the device for that. –  The Evil Greebo Jan 5 '12 at 19:49
