My oven light burnt out recently. After dismantling it I found a 40w 130v "appliance" bulb with a standard Edison connector. The bulb is slightly smaller than a normal incandescent bulb. Looking for replacements at the local stores, all the similarly sized and shapped bulbs list fans and fridge/freezer as acceptable uses. The few ones I can find that actuall list ovens as a use case the wrong shape, size or base.
So do I really need an "oven bulb", or will the fride/freezer appliance bulb work?
