Tell me more ×
The paint is dark red and has dried. It only covers little areas on the plastic of the window frame.
How do I remove it without damaging the frame?
The frames are white.
Goof Off 2 is made for removing paint from plastics.
Do you have any evidence to back up this claim? – ChrisF Mar 17 '12 at 22:29
Only that I use it all the time for removing paint from plastics or where I'm afraid the full-strength Goof Off would be too caustic. Always try in a hidden or small place first. Hope this helps. I've been very lucky with this stuff so far--no problems yet. – rons Mar 20 '12 at 22:37
I've had good results with rubbing alcohol or ammonia.
